keitho64's Avatar
69 Fuel Tank Sealing Rings
My fuel tank is seeping gas from the three fittings on the bottom of the tank. It looks like the copper sealing rings are the culprit. I found the parts diagram here and it looks like parts # 22, 24 and 28 are what I need. I was not able to find them on the catalog to order them. Do you know if these are available?
I am also trying to find the copper sealing rings that go on the fuel inlet on the 40IDA's. I see we can get the complete Banjo replacement kit here from PMO but I would prefer just to replace the seals. Do you know if these are only available in a weber rebuild kit?
I tried the local hardware store but have not found anything yet.
If any of you have ideas where I can get these I am all ears.
Thanks.
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 01-23-2014, 05:55 PM
AutoBahned
RWebb's Avatar
check Stoddards - they often get new parts made when out of stock
the other question is what sealant to use (if any) - Locktite 518, a Dow Corning product, or...
Old 01-23-2014, 06:05 PM
