onyxco's Avatar
Engine Locknuts:Nylon or Spring Washers on 1973 Engine!?
I am in the process of restoring a 1973 1/2 911 and putting my ENGINE parts and hardware together.
Q: Did nylon lock nuts exist in 1973 and if so, were they used on this year 911
or
Was it a standard nut with spring washers as it seems the parts diagrams depict?
Thanks All!
Old 01-25-2014, 04:26 PM
AutoBahned
RWebb's Avatar
Ny-locks will work a LOT better than a standard nut with spring washers unless they are in a very hot area.
Or are you nuts about concours?
Old 01-25-2014, 04:47 PM
onyxco's Avatar
I totally agree... I am not going to show the car but am doing a restoration just on this side of perfect so,, I want to try to stay with original.
Old 01-25-2014, 04:55 PM
Send a message via Skype™ to Porboynz
I remember that the gearbox nuts on my 1972 915 where like nylocs but are all metal with a sort of crimping section where the nylon is. I replaced them with nylocs, but kept regular nuts and lock washers on the engine fasteners. Maybe use both?
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 01-25-2014, 11:02 PM
non-whiner
mreid's Avatar
Nylocks were not used on your year, but are much better than lock washers and the old style deformed steel lock nuts (except in high heat applications). I would use nylocks for the intake manifold and other areas where a loose nut could create a vacuum or fuel leak.
"Too much is just enough."
Old 01-26-2014, 05:43 AM
Tags
nylon lock nuts
