Has anyone replaced Front Floor Pan Half
Has anyone purchased from our host or from stoddardd the front floor pan half? If so whats in the hardware kit that comes with it. Our host also offers a front floor pan half from tasker, whats the difference from either manufacturer?
1966 912 with 2.2 911 motor 1986 wide body 911 1995 993 Polar Silver |
Restoration design had the part for a fair price.
I measured then drilled out the spot welds. Then I ground down the drilled out welds and hammer and straightened the flanges. I fitted the new pan to the car to check for fitment and made the needed adjustments. I used an alignment plugs to keep the pan in place then started welding. Do not weld around the pan's perimeter as it will warp the metal. I was told to skip around and I had no warpedge. Finally I touched up the welds with a grinder cleaned the metal and prayed the welded areas. I used seam caulking and Por paint. Come over if you want to see it.
67' tangerine targa |
