How to Remove sound deadner
What is the best way to remove sound deadner, in a early car?
Old 01-26-2014, 06:46 PM
air+fuel+spark
combatic's Avatar
These were generally my weapons of choice through out my stripping process.
The oscillating multi-tool works best on hardened material. If it is still flexible the abrasive wheel or flapper discs work better.
Don't forget about ventilation/filtration mask! Hope that helps.
bryan
1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle
R Gruppe #653
Old 01-26-2014, 07:34 PM
Send a message via Skype™ to Porboynz
I chose a cup shape wire brush mounted into a standard angle grinder. I have heard good reports about the oscillating multi tool with the non serrated flat blade.
Gloves, earmuffs and a full face mask and safety glasses/goggles are preferable. I initially had just safety goggles on and had to pull a piece of wire out of my forehead when I stopped for a break, I did not even feel it go in. After that I put on a shield like a welding mask.
I also tried an air chisel, bad idea, OK on the flat but it made a hole as soon as it got near a moulded section of floor pan.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 01-26-2014, 09:01 PM
Heat gun works just fine, then a clean up with thinners.
911SC 79, Aussie delivered, matching numbers, originally Cashmere Beige, painted black, Fibreglass update front, back and sides. Now going back to original restoration
2015 Jeep Cherokee Sport or the wife. Ford territory on gas (the work horse).
Old 01-26-2014, 10:10 PM
Sound deadener
A bucket of results of my sound deadener removal off my 79. Tar like substance. Easily scrapes off with some heat.
Old 01-26-2014, 10:14 PM
I first tried a scraper, but it chewed my hands way too much. I then bought a cheap wood chisel (about 1/2 inch wide), and used that as a scraper. It has a far better handle than your average scraper, and as it is sharp it is really useful at stripping off the undercoating. The stuff pealed away in no time.
I followed that with a cup brush on an angle grinder. Once all was done I took to the panels with a cloth liberally soaked in mineral turpentine, and finally finished the job off with an ammonia based cleaner. Did this all before I even knew of Pelican and was really surprised to see so many complain about what a tough job it is.
Oh yes - I tried to see if a heat gun would make things easier but that was just messy. Parking the car in the sun for a few minutes was far more useful.
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Old 01-26-2014, 10:29 PM
Heat gun and scraper, then solvents. No need to damage whatever finish remains on the floor pan.
JR
Old 01-27-2014, 05:24 AM
Undocumented User
McLaren-TAG's Avatar
I used the straight pick from my Snap On pick set. Was able to place it at a low angle under the tar and with slight pressure the chunks would break off in large 2 and 3 square in pieces. Did both sides in about 45 minutes.
Old 01-27-2014, 05:39 AM
El Duderino
tirwin's Avatar
I was able to use a sharp chisel and a hammer to break up the stuff. It was a little easier in my case because some idiot (ok... an idiot prior to me) tried to jack the car from the floor pan. When the floor pan dented upwards it cracked the stuff so at least I had a good starting point
The stuff some people do, right?
You know there is a bright side to being foolish. Sometimes I just think about all the great experiences I would've missed out on if I had known better. The crap in the bottom of the floorboard. Replacing the headliner. Being able to start the car without a screwdriver. Fixing the shifting problems. Getting the CIS sorted out. Hunting down electrical gremlins. Taking care of some rust before it became a real problem. Yea... good times.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 01-27-2014, 07:44 AM
Mine took a little longer but definitely did not need mechanized assistance. Did they use different materials over the years?
1982 911 Targa, 3.0L ROW with Webers
Old 01-27-2014, 08:24 AM
AutoBahned
RWebb's Avatar
Is that just the rear firewall or the entire floor pan?
also, did you weigh it?
Old 01-27-2014, 11:26 AM
I weighed mine...
From a coupe built in 1977:
L&R inner door pads 987.5 grams
Right front bulkhead (2 pieces) 469 grams
Right floor 2859 grams
Left floor and bulkhead 2796 grams
You might add a handful of grams for the tiny amount not removed by mechanical means that was removed by solvent.
No questions about the scale accuracy, please. It's fine.
I'm not aware of anything on the rear firewall.
For those keeping score, I think the stuff put down in the era of the 3.2 Carreras was a little different.
JR
Old 01-27-2014, 01:54 PM
kinein's Avatar
Send a message via Yahoo to kinein
so what should I use to take out the sound deadner in my 66?
1966 912 with 2.2 911 motor
1986 wide body 911
1995 993 Polar Silver
Old 01-28-2014, 06:40 PM
AutoBahned
RWebb's Avatar
Old 01-28-2014, 06:48 PM
911oclock's Avatar
I believe you can use dry ice on the floor pan
Old 01-29-2014, 04:31 AM
It's easier to use a heat gun and a scraper.
JR
Old 01-29-2014, 04:36 AM
