OBD error codes, advice please
I got a check engine light yesterday on my 1999 C2 and as it turns out, my durametric (clone) cable just gives me a red light so I can't connect it. But I picked up a code reader from Harbor Freight today.
I get the following codes: P0102 P0446 Any idea on where to start? Anyone experienced these? The car starts and runs like it always did ![]() ![]() ![]() ![]() ![]() leave car or drive car while figuring this out?
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush youtube.com@mariusdrives Last edited by mhariush; 08-23-2014 at 10:44 AM.. |
Assuming it is a 1999 car: P0102 - Mass airflow sensor below lower limit; likely faults: break in the wiring, short to ground. P0446 - EVAP canister shut off valve below limit; likely faults: purge air line blocked, flow blockage in the EVAP canister
Hi, thanks. Yes, 1999 C2.
I see the codes, and I found what the OBD manual says about it. Is there any thing I should check before that? Is this commonly caused by something? Someone also asked me if I had occasional trouble starting the car, and yes I do. If takes a few extra cranks to start it, I think. And a few times I tried starting it but it didn't, I had to wait a minute and try again. Here's the OBD manual steps. Just start going through them then? I don't have the Special Tool, can I get around not using it? P0102 ![]() ![]() ![]() ![]() P0446 ![]() ![]()
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush youtube.com@mariusdrives |
You can get around using the "special tool", which is a Porsche specific pin out box, but it is going to be a lot more time consuming as you would need a digital multimeter and the car's wiring diagrams to test the circuits.
I cleaned the MAF. The air filter and inside of the air box was fairly "dirty" for a filter I replaced in July.
Cleared the codes. Let's see how that goes. Live OBD data.
