Catching-up with CSF Radiators at the 2014 SEMA Show
This year's SEMA Show was as strong as ever with plenty of new products on display as well as exciting project cars. We took a few minutes and stopped by CSF Radiators as they featured the gorgeous BBI/CSF/Liberty Walk Porsche 997 Turbo front-and-center within their booth for all to take a closer look.
Among a long list of modifications, this Turbo features CSF's 3-piece all-aluminum 997 Turbo high performance radiator package (left, right & center radiators) for maximum cooling at the track or when carving your favorite canyon roads. Featuring a drop-in fit and retention of the OE quick disconnect fittings, the CSF units provide a 40% increase in cooling capacity and 15% to 25% cooling efficiency over the stock 997 units.
This Turbo has such an aggressive look and the following additional modifications should make it a track day monster:
  • Porsche 9A1 3.8L twin turbo with BBI B7 Tuning Package producing 688whp at 21lbs of boost on 91 octane
  • BBI stage 3 clutch & Aasco lightweight flywheel
  • BBI Stage III suspension package featuring Ohlins dampers
  • 18x13-inch rear & 10x10.5-inch front BBS E88s with 335/30R/18 rear & 265/35R/18 front Toyo R888s
While visiting with CSF, we also learned more about their most popular Porsche fitments that started it all - the 996 & 986 units, which solved the all-too-common problem of the OE radiators cracking and leaking coolant due to the plastic mounting tabs and excessive vibration. CSF addresses this issue with an all-aluminum end tank along with CNC machined brackets, fittings and mounting pins.
Check out the pictures below of the left, right and center CSF radiators on a 996 Turbo:
CSF Radiators are perfect for both street and track applications and have been proven time and time again under the harshest racing conditions.
All CSF models include:
  • B-Tube Technology - most efficient tube in the world
  • Two-row core with optimized density for maximum surface area and airflow
  • Drop-in fit - no hassles!
  • Extensive vibration, thermal, corrosion & leak testing
Pelican Parts is proud to offer CSF Radiators for the following applications:
Let us know if you have any application or technical questions - we're here to help!
Mark/Pelican Parts
Old 12-09-2014, 10:30 AM
