Dman (guest)
Guest
Posts: n/a
2001 Carrera vert. you talk about the exhaust cams in the paragraphs then the intake cams in the step procedure. Im confused. My IMS Retrofit kit came with cam locking tools but you never mention using them, you actually say rotate the engine after removing the tensioners??? Nobody out there in porsche land seems to do it the same. Some places say remove all 3 tensioners, you say two. You don't specify exactly which plugs to remove the access the cams - nobody explains it clearly BTW - the front of the engine rear of car or the rear of the engine flywheel end. Can you clarify? We bought your bearing kit too.
Old 06-10-2015, 04:44 PM
NEVER rotate the engine with the tensioners out. I just skimmed through the article and didn't see any mention of that. Wayne didn't use the cam tools because at the time he wrote this there were no cam tools available to the DIY'er. www.youtube.com/watch?v=hAxj6FKMzvM Here is a video I helped make with Bentley that should make the process easier to understand.
- Casey
