Guest
Posts: n/a
My 2004 911C4S has a rough idle that makes the car vibrate. Just a slight increase in RPM makes it smoothe out. I've changed spark plugs, fuel filter, air filter, cleaned the injectors and throttle body. Even replaced a worn out transmission mount. Runs great at speed but shakes when idling in stop and go traffic. Seems to worsen the longer I'm running the car at any one time. CEL is not on. Could this be an MAF problem even though I have no CEL alarm? What suggestions do you have?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
I've noticed that a few of the 2002-2004 996's have a lumpy idle. It was the flywheel on a few of them, and an IMS retrofit to the LN IMS Solution on another handful of them that felt the issue was worthy of a couple thousand dollars. Most of the cars however lived happily ever after with the vibration. Another thought is to check the motor mounts.
- Casey |
