Changed Battery now Odometer shows 999,999
Had to install a new battery on my 1999 996. After the battery change the odometer is maxed out at 999,999 miles, The trip odometer works. Also the digital speedometer read out is in KM instead of miles. Has anybody seen and fixed this before. I did a search, tons of info on Odometers but I could not find anything regarding this issue. Thanks
Found the Fix! to the Million Mile Read Out
Over on the Rennlist a guy had the same issue with a 99 Boxster, A mechanic provided the fix, see below. It works
Disconnect the negative cable with the key in the ignition. Turn key to position 1, let the car sit long enough to bleed off any power, then turn key to off position. Then hook up negative cable. |
Porsche 911 Carrera S
Can anyone comment on whether this weirdness could have been prevented with a Powerbuilt 648539 Computer Memory Keeper?
I've never used one in all my years of vehicle ownership but from all I read it seems the 911 electronics are hypersensitive. |
Fullthrottle52
Just drive it one mile and you have a new car!! 😀
