Chilly starter
Last winter the starter on my 03 C4S daily driver was, at times,a little finicky when ambient temp was down to about 45 degrees or lower. A couple good depressions of the clutch pedal and she would turn over as strong as ever. Come spring time the gremlin was gone and I had completely forgotten about it. Well, guess what? It's back.
Battery is fresh and fully charged and all electrical systems appear perfectly normal otherwise. Has anyone heard of a clutch pedal switch being temperamental to cold temps? Any other thoughts ??
Thanks, Paul
Old 12-29-2015, 12:04 PM
Make a jumper to connect the two wires on the clutch switch and see if the problem goes away. Note the cruise may not work if you do this.
Old 01-06-2016, 06:30 AM
I've had the same issue the last two winters and suspected the clutch switch. When it started getter cold this year and the problem returned I ordered a new switch, installed it, and have not had the problem since.
Old 01-07-2016, 09:04 AM
