Emergency release cable location?
I couldn't find the answer after some searches here, on Google, etc. Apologies if this has already been answered somewhere.
I'm curious where the emergency, manual trunk release cable should be on a 2004 C4S. Is there one for the front only, or also for the engine lid? On my 986, I ended up re-routing the front cable to the tow hook location. Is the front cable on a 996 in the passenger wheel well also? Is there a rear cable too? On my 986 the actuator for the front trunk failed and having the cable was hugely important (since it wasn't a simple matter of jumping a dead battery), so I like to be prepared ![]() Thanks! |
The front cable is inside the upper front passenger side fender liner, unless someone has moved it. You can see it with the right front headlight assembly removed.
The rear cover cable is under the left rear tail light fixture. The problem is that it cannot be accessed that way because the light fixture cannot be opened (by a single nut) unless the rear engine cover is already open. I pulled my cable out toward the rear of the tail light fixture opening and then used duct tape to secure it there so that it could just be fished out with a small hook if ever needed. Some folks pull it out the bottom near the left part of the exhaust system. Good luck.
2015 Porsche Macan S, Dark Blue Metallic 2011 BMW 328xi, Crimson Red |
Thanks 88... this helps a lot. Very strange they made the rear cable inaccessible if the lid is shut. Not sure I understand the thinking there. Any idea what the rational was? Oh well, thanks again!
2002 Boxster S 2004 911 C4S |
You can fish the rear cable out with a thin wire hook and a rubber spatula gently wedged between the light assy and bumper.
Sometimes you can see/fish the front one through the marker light hole. It just snaps out.(the marker light)
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 Last edited by FPB111; 04-04-2016 at 03:46 PM.. |
