Clutch hose fittings
Hi all,
RE:996
I am trying to remove and replace my clutch hose line that is connected to the slave and the hard line. I tried to use two 15 mm wrenches one of which is a flare wrench. With much force I tried to loosen the union, but no luck, I'm afraid that if I try too hard I may strip the brass fitting.
Any suggestions?
Here is a pix...
Old 06-18-2016, 10:53 PM
Tags
996 , clutch bleeding , hydraulic lines
