How to know when its time to replace clutch
Hi- I have a 99 C2 with 95k, the clutch has about 65k due to a previous replacement. It is a little sticky to find 1st, other than that-no issues, and no slippage.
What are the symptoms that lead to a clutch job on these cars?
Thanks in advance for your answers.
Old 08-12-2016, 04:52 PM
Besides slippage or noise, normally you would see a change in the clutch engagement point as well as an unexpected increase in the pedal effort.
Old 08-12-2016, 06:40 PM
jwetering's Avatar
As above - but note that increased pedal effort may also be an issue with the clutch helper spring.
Maybe also consider clutch judder/chatter as a warning sign.
If I remember right, my clutch went at closer to 100k miles.
jasper
Old 08-18-2016, 01:08 PM
Administrator
Hey inaminit,
Our members have given you great suggestions; as I'm sure you know waiting too long causes headaches and empty pockets! I've included a reference guide for you to know exactly when it's time to replace the clutch. Be sure to check out our other Technical Articles on the 996 for any additional info on servicing or repairs. I've included links for you below: Cheers!
Clutch Replacement on the Porsche 911 Carrera - Porsche 911 Carrera Clutch Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
Porsche 911 (1998-2012)
Technical Articles - Porsche 911 (1998-2012) Technical Articles - Porsche 996 & Porsche 997 - Pelican Parts
-Dmitry/Pelican
Old 08-18-2016, 04:21 PM
wolds's Avatar
If it's worn it will initially slip in high gear under load (like going up a hill). As it gets worse you will start noticing it slipping in lower gears.
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 08-24-2016, 08:11 AM
