996 turbo hard acceleration cut-out
Has anyone experienced this problem? Idles, and runs fine otherwise. It suddenly started, and no check engine light displayed. 26,000 miles.
Maybe a fuel delivery problem, try a bottle of Techron fuel cleaner along with fresh Chevron Supreme fuel top off. If you notice a improvement may have some clogged fuel injecters. If no improvement the fuel pump may be weak, check fuel pressure at high RPM if possible.
I know absolutely nothing about 996tt's, but if it was a 930 and it cut out during hard acceleration, it probably would be the overboost switch.
Does it happen at exactly the same revs? regardless of gear select? that could give some insight. |
No check engine light???
I have seen a few of these cars exhibit that when the valve lift control bracket breaks on one bank... Causes misfire faults on one bank only and sometimes the DME thinks that the O2 sensors are switched (crossed) which is not even possible haha. Here is a link to the tech article |
Turn off the PSM and try it. PSM will start to cut out engine via e-throttle under certain conditions.
Fred Larracuente
I had a similar experience recently after power washing the vehicle (which went away after a few hours of running) and another time after a really rainy day. It came down to water in the coil plugs and the engine connector on the right side of the engine bay. That connector in particular is not waterproof so water can get in there quite easily.
Hope this helps, Merry Christmas!,
Fred Larracuente Guaynabo, Puerto Rico '03 Carrera 4S - Seal Grey '99 Boxster Artic Blue/Tan interior 30.5K miles - SOLD!! '73 914-4 1.7 STB 2.0! Alaska Blue |
Rev limiter for exceeding redline ?
