996 not start. Electric down ..
Not run motor start only
My idea is failure immobilizer !
Mine is failure battery.
First step clean battery terminals and cable ends well then retry. You could try a jumper box and see if it will start with that. If so most likely battery or dirty cables.
Ok tanks i have alredy change the battery end cable exsternal it same problem !
No have contact on key out I change electric contact it is a same. !! I have start on the motor starter direct end it is ok. 996 run perfect. ! Who is a problem ? Inviato dal mio HTC One M9 utilizzando Tapatalk |
Check the clutch switch? Jumper across the two wires with a spade connectors jumper.
Check the "Y" cable in the engine compartment. Also check the ground from chassis to engine, right side near rear tire. Have you checked all fuses?
I have cecked all fuse in pedal zone Who is the clutch switch ? Zone ? The cable Y it is ok Inviato dal mio HTC One M9 utilizzando Tapatalk |
The clutch switch is above your toe when your foot is on the clutch. See fig1
Porsche 911 Carrera Brake Clutch and Cruise Control Switch Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
