2003 Porsche Enthusiast
Fault Codes P0442, P0445
My duremetric states fault codes are Leaks detected in Fuel system. Is it recovery vapor system? If so where do I start testing. Gas cap seal is good. Having trouble filling my gas tank to the top. Car will stall every now and again. Throwing fault codes. Clean throttle body and Maf sensor. No vacuum sound when opening gas cap. Seal is new. Can I test bleeder valves and how?
Thanks Vin |
P0442, p0445
Thank you for the reply. 2003 Porsche 911 Carrera 4 Cab. with a 996 engine.
P code info is greatly appreciated. Will look into replacing this. You where very helpful. I hope this resolves my issue. Thanks Vin |
