99 996 brakes slowly lock up.
Went to the track car ran fine unloaded it went for a drive and with in a 15 to 20 min front brakes would slowly lock up.
I pulled the brake booster valve the car would roll again. Change booster and master still the same. I pulled the and fuse, same. I then tried to adjust the push rod To soften thinking not retracing back far enough, same. Car has steelbraded brake lines the one that are plastic coated and are in good shape. Any ideas? |
Had same problem with 2001 996 turbo ended up replacing abs pump/valve unit that fixed
The problem was big $$$ could not find used one |
Moving to 996 forum
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
