Is this normal on startup?
I am the new owner of a 1999' 911 Carrera coupe.
I notice on start-up a loud fan running at high speed turns on. Sound seems to be coming from drivers side front? The noise sounds excessive. Like the fan is running full blast. After about 3-4 minutes the fan shuts down (or slows down) and I can no longer hear it. Does this every time I start car in 'Cold' condition. Doesn't seem to happen if I drive around and stop and then start again say after stopping at a store. the car runs perfect otherwise. Just that VERY loud fan running at high speed on cold start for 3-4 minutes. Normal? thanks |
unindicted co-conspirator
it's probably the SAI (secondary air injection) that sometimes sounds like a hair dryer
it's in the engine compartment on the drivers side next to the coolant tank it comes on for a min or 2 at cold start try unplugging it before you do the next cold start and see if the noise is still there
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Normal the Secondary Air Injection pump is a pollution device that helps light the cats quickly. If the fan is really LOUD it might need to be disassembled and cleaned. Search the web for cleaning 996 SAI fan. If it fails a new one is available from Bosch, you have to reuse the Porsche bracket, for under $300 or the same one in a Porsche box is available for ~ $1,100.
When you unplug it you will get a CEL. Plug it back in and after a number, 1 - 100?, Of successful starts the light should reset.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 Last edited by FPB111; 10-14-2017 at 03:38 PM.. |
OP states a fan in the front of car, not in the engine compartment.
I feel he's talking about one of the radiator fans in the front wheel fenders. I believe those radiator cooling fans should only turn on when they get a signal that the coolant has become hot beyond normal operating temperature. I'm sensing that there's going to be a sensor or a resistor or a bad switch or relay that is going to be involved with this resolution. Electrical gremlin(s): aaargh ! |
If he's starting the car in the garage, it could sound like it's coming from the front
Also, if the AC is on, the fans come on as well - maybe the OP has the climate control set on AC?
