Brian Minson's Avatar
Things to do before installed USED C4 Tip gearbox?
I picked up a used early C4 Tip gearbox and want to make sure its ready to go before installing in into my 996. Here is what I plan to do:
- replace transmission mount
- new filter/seal and fluid (after its installed)
Should I replace the diff seal? Are there any other areas I should look at before reinstalling it? Any tips on the R&R would be helpful from those who have done one before. JFP in PA has been an amazing resource thus far, thank you man!!
Brian
Old 01-17-2018, 10:48 AM
RMS, IMS, AOS at a minimum.
Old 01-17-2018, 11:35 AM
JFP,
RMS and AOS were done when the IMS was done about a year ago glad that is done! lol Anything else good sir?
Brian
Old 01-17-2018, 01:45 PM
Originally Posted by Brian Minson View Post
JFP,
Brian
That's all I have. good luck!
Old 01-17-2018, 02:23 PM
Change the fluid now. It is a lot easier filling it from the top.
Old 01-18-2018, 05:30 AM
JFP,
Brian
Something came to mind: With the new trans out of the car, this is your only time that you can drain both the trans AND the converter of old fluid. By doing this now, you would start with all fresh fluid.
Old 01-18-2018, 11:43 AM
JFP, what is the best way to do this?
Brian
Old 01-18-2018, 12:40 PM
You will need to remove the converter and turn it snout down into a large bucket, and then leave it there overnight to let the fluid drain out. Then reinstall the converter and put the assembly in the car.
With the trans out, it is the only time you can fully drain the converter, which holds the lion's share of the old fluid.
Old 01-18-2018, 02:10 PM
Then prefill it via the top per yelcab1's suggestion, if I recall that's 9 liters of ATF?
Brian
Old 01-18-2018, 04:39 PM
