Intermittent Key Operation
2002 C4, new battery in keys, will not lock or unlock but only intermittently.
Anyone have experience with this?
Thank you
Old 02-07-2018, 03:31 PM
Will the key work after you put it in the ignition? How much time is passing between when you use the car?
Old 02-15-2018, 07:25 PM
I havent got my key remote on my new to me 2000 to work yet. So when doing some resesrch I did read if u dont start the car within 7 days it will self deactivate the remote. Maybe that your issue?
Old 02-16-2018, 12:38 PM
That is what I was thinking
Old 02-17-2018, 11:19 AM
I bought an 03 Targa and it started having the same issue. Door lock, trunk or hatch worked sporadically. It had a new battery in it,but it still did not work.
I was told that I needed a new key by a friend who works at a local Porsche specialty shop. He could not order one, so it was ordered by a dealer, then they had to program it. Very costly!!!
2003 Targa 996
2009 Cayenne GTS 6MT
Old 02-18-2018, 10:00 AM
I thank all of you for your replies....
I will have to check my settings because there were no notices that there were responses.
The problem persists....The car will lock but not unlock, then it will unlock but then not lock.
Phil Noble, I think I will have to order a new key and go through the 'costly' process you went through. How costly was it?
Old 02-23-2018, 04:35 PM
I had to order the key thru a dealer from Germany, showing car ownership of course. Once it comes in(about 2 weeks), you take all your keys and have them programed together(about 1 hour). $500+ later, you have a new fully working key and a backup key that still works sporadically.
Call your local dealer, and discuss what they need in order to get a key.
Good luck!
2003 Targa 996
Old 02-23-2018, 06:11 PM
