Another Temp Guage Question
Here is my situation... 1999 Porsche 911 C4
I went to the race-track and overheated the car... after that when I started the car when it is cold the temp pointer is pinned to the right and the light blinks slowly, but after a little bit of driving the temp pointer reads temp accurately and light turned off. After completing the following "fixes" when I start car cold the light blinks fast and the temp pointer is to the right, but after a little bit of driving the temp pointer reads temp accurately and the light blinks slowly. If I start the car warm the only thing that happens is the light blinks slowly. To fix the initial issue I did the following: Replaced the coolant tank, Replaced the reservoir CAP with the black one Replaced the coolant level sensor Replaced the Engine Coolant Temperature Sensor I also tested the engine compartment blower and it works fine. My only guess is that the wiring on the coolant level sensor is broken. When I replaced the tank I noticed the old one was not mounted in the car and was able to flop around. Any ideas? Thanks 1999 C4 996 911 Last edited by mckress; 05-18-2018 at 03:11 PM.. |
If the light is till blinking you probably have air in the system. There are a lot of
coolant lines and gravity bleed won’t necessarily work. You need to pressure test to ensure you have not cracked a head. The 3.4 cars are prone to head cracks when the engine overheats. |
Thanks... sounds like a typical user error issue... looks like I need to get it professionally flushed... my home done gravity flush may have left some air pockets. I'll keep you posted,
| Tags |
| coolant , guage , temperature gauge |
