Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
thekidd's Avatar
Send a message via AIM to thekidd
audi a4 thoughts
Im an active member in the porsche forums, but am looking for another car. Was looking at getting into an audi, or a VW. Mainly looking at A4, maybe A6 or GTI/ Jetta, The compacts. Not looking to spend over 1500, but for the right car comes the right price. Can do work on the 944 series, so I believe i can learn quick about Audi/ VW mechanics. saw this ad 1998 Audi A4 Quattro 2.8L
Whats your guys thoughts? Locked in N/1st gear? Wouldn't it be one or the other?
Fairly new Cam tower gasket, brakes n rotors, plugs/ wires, clutch and pressure plate. Is the throw out bearing inside on of them? 944 it is a separatepeice, P. plate, clutch disk, and T.O. bearing (3 piece clutch).
What are some of the fixes for the stuck gear? Don't know much about the A4. Any help would be awesome.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 08-12-2014, 01:51 PM
A4 2.8 is a great move. Can't go wrong if you are handy. I had a 3.0 that I loved.
Old 08-16-2014, 08:15 PM
thekidd's Avatar
Cool cool. What are your thoughts about the stuck gear? Could it really be as "simple" as reconnecting/adjusting the shifter? Or do you think he did something to the tranny after the clutch job? How would you go about diagnosing that, and onto fixing it? Would I be essentially doing the clutch all over agin?
Old 08-17-2014, 06:45 PM
Start by reconnect/ adjusting the shifter. That should be tough. If that doesn't work I suspect whoever did you clutch screwed it up. Try readjusting the clutch cable. I have a feeling when he pulled the tranny out to do the clutch. He didn't renegade it properly.
Old 08-17-2014, 09:10 PM
Was the cable replaced or the clutch pressure plate/disc throwout bearing?
Old 08-17-2014, 09:11 PM
thekidd's Avatar
He did not mention that he replaced the cable. Is that a piece that should have been replaced while he was in there? He said that the he recently replaced the clutch and pressure plate.
Old 08-18-2014, 01:44 PM
