Why do they use plastic for chain tensioners?
Everyone has seen this scary Audi V8 photo.
Why do they use plastic for chain tensioners? It seems like this is not just Audi, but most car makers. Are you simply unable to use metal on metal? Are the plastic guides a sort of the sacrificial layer, albeit one that lasts 100k? ![]() https://www.reddit.com/r/pics/comments/3fm4t7/inside_an_audi_b6_42l_v8_engine/ Quote:
1986 Bosch Icon Wipers coupe. |
Member 911 Anonymous
From my experience every car I hacked on had plastic type chain guides, I am guessing better to have plastic residue vs metal???
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
These are pretty specialised plastics used to keep full control over the chain (prevent any lashing about) and be quiet in the process. As the other post says it's also better to have a few bits of plastic dust in the oil over metal swarf. I believe the chain rollers should run on the plastic rather than the chain side plates - I have seen badly worn plastic chain guides when the wrong spec chain was used. Fords have used a small block of rubber as the wear surface on the end of a chain tensioner and they last well if the chain has ground side plates
Frangible stuff should be easier to service, like on my 911sc ..it's all right there easy to access those plastic 'ramps'
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
I own four cars. All with timing chains.
What's going on in the background of that picture? The world's biggest micrometer?!
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
