supertack's Avatar
BMW Roundel Squeeking Clutch
My clutch is begining to squeek when its depressed at the uppermost spot. I listened closely & the sound doesn't really sound like its coming from the pedal, but from the engine compartment. Does anyone think it may need clutch fluid, & if so, how do I add/change it? If its not clutch fluid, where & what should I lubricate?
Thanks guys
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 02-28-2003, 09:15 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Almost always, the brake reservoir is also used to feed the clutch assembly. Check your brake fluid level. I would also inspect the mechanicals going from the clutch master cylinder to the slave cylinder. Maybe something needs attention underneath.
Old 02-28-2003, 09:28 AM
stupenal's Avatar
I'm sorry I don't know the answer to this question, but if it makes you feel any better, this is a VERY common problem on e36s. Its come up many a time on other boards, but I've never really looked into it.....
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 02-28-2003, 01:16 PM
supertack's Avatar
So are the brake fluid & clutch fluid separate? Why would low brake fluid case the clutch to squeek? Also, whats the easiest way to check the break fluid level?
97 328is
Old 03-03-2003, 07:19 AM
914 Geek
Not sure if the brake and clutch fluid are separate or not.
Low brake fluid, on its own, would not cause squeaking. However, when the brake fluid level gets low, it is often because there is a leak somewhere. When the leak is from the brake (or clutch) master cylinder, the fluid can wind up on the pedal bushings. These will swell up (some) on contact with brake fluid, and will squeak.
...At least, that is what happens on 911s and 914s... I assume that it's a similar mechanism on the Bimmers.
You check the brake fluid level by looking at the reservoir in the engine bay. There should be "MIN" and "MAX" levels on it, and you should be able to see if the fluid is in between those lines.
--DD
Old 03-03-2003, 08:19 AM
