BMW Roundel DME fault codes
I have Wayne's two books; great resource. My '85 E30 with 6 cyl and 5 speed (205K miles) has been acting a bit woozy-hesitating and stumbling on acceleration.
Does the gas pedal method work with the M-tronic 1.0 for reading fault codes? I can't get it to.
Jim
Old 07-30-2018, 04:38 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Jim - welcome to the forum! Take a look at the link below to one of our site's DIY tech articles - I hope it'll help you troubleshoot your issue.
https://www.pelicanparts.com/BMW/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm
Old 07-31-2018, 11:22 AM
High Life's Avatar
Jim
No - Stomp method only works with a DME of 173 or later. (Motronic 1.3)
Give me more of a description and maybe I can help you diagnose..
1981 911SC
Old 07-31-2018, 08:31 PM
Thanks, I thought there was a limit to those older units.
I am continuing to diagnose it. One item is I use a K&N air filter and the mass airflow sensor is just downstream. People have said to clean it with special cleaner and this might be it.
I also just adjusted the valves and I'm getting a "tick, tick, tick" but it runs smoothly, just givee me the hesitation. Do I need to re-adjust the valves?
Jim
Old 08-01-2018, 12:16 PM
High Life's Avatar
Jim
Without knowing specifics - make sure you have no vacuum leaks - the M20 engine will run poorly when a leak is present. A smoke machine is the best tool to diagnose and find the leak... if you don't have access to one - I run a vacuum gauge to determine if i have a leak..
A good running M20 sounds like a sewing machine... which makes knowing when to adjust valves a little tricky.. For me the sewing machine sound gets more pronounced, it sounds a bit more diesel ish.. a much louder ticking.. If you just adjusted the valves - you are probably ok, its a fairly simple procedure.
1981 911SC
Old 08-03-2018, 05:59 AM
Thank you; am still on it.
Old 08-05-2018, 12:45 PM
Tags
computer error codes
