Climate control doesn't light up
Does anyone know what steps are needed to get my climate control lights to work? At one point if i banged on the side of radio/climate control, it would pop on. Now, the whole section is dark. Im wondering if its a bulb, like the clock light i had to change. If anyone knows, email me at darkeyedangelz@aol.com
thanks. Angela |
Interior illumination seems to be a problem with Bimmers. My stereo display light started half as bright when I bought the car, but would intermittently go to full brightness for a few seconds. Now its always out, & intermittently goes to half brightness for a few seconds. Ive read of a number of people talking about this problem.
My odometer display has the bottom half of the numbers drop off & switch to KM instead of Miles periodically, but will go back to the normal display after a few minutes. Both of these issues seem to act up more when its cold, & first started this winter.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
Administrator
The knocking on the side of the bin leads me to suspect a loose wire. A bulb will typically go out when knocked around, though it may get bright for a little while first. (In household lightbulbs, "a little while" is about 1 second.)
You're probably gonna have to disassemble stuff so you can check all the wires... --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
