			I've got a 94 325i, automatic, with 102k on the clock.  Recently I started hearing a grinding type noise and feel vibration from under the car when turning at low speeds or from a stop.  More specifically it sounds like I'm driving over a rumble strip on the highway.  The sound appears to be coming from around the transmission area.  I checked fluid levels in the trans. and all seems well, no burnt smell or dark color.
				The car runs and drives fine otherwise. Any ideas? Thanks, Steve  |
			 Senior Advisor
			Check the drive shaft ie, the guibo or center support, the guibo is that big rubber thing that connects the shaft to the trans....
	...96 Chevy heavily Modded such items include... lil' pine tree air freshner.... duct tape rht front arm rest (i'ts falling) zip tie holding in rear tail light.... hi concentrate windsheild washer fluid... sticker of Speedy Gonzales..rear bumper...  |
			 In the shop at Pelican
			I second javier, check the center support. Sounds like it's on the way out.
			Wow, you guys are fast!  I'll do so this evening and let you know what I find.
	1994 325i and proud of it  |
			Power steering leak?  Our cars are known to leak power steering fluid.
	1997 M3 Sedan 5spd Artic Silver/Dove M3 Bumpers/Mirrors/Sideskirts S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes Oh wait...it's a stock M3  |
			yea, mine is leaking power steering fluid on both hose (in and out?) is this a job one can do at home or have a mechanic do?
	--j  |
			I read that it shouldnt be too hard to replace the clamps on the hoses.  That is whats causing the leaking.  Mine leaks really really slow, so i havent addressed it yet.
			Hello all,
					I found the source of my problem. The exhaust mount at the cat had been bent just enough to cause contact with the body when turning. I now recall having driven over one of those 'speed mountains' they put in these days in parking lots, and hearing a scraping noise; I bet it happened then. My driveshaft and 'donut' appear to be fine. Thanks for all the suggestions! Steve
