Question Window Reulator?
Hey Everyone~
I am having a problem with the driver side window on my '93 325is, it will only go down when i apply light pressure on the window and push down, and it will not come up at all, i had the door panel off today, the motor is working fine but the big half-circle gear (if youve had the panel off you know what im talking about) seems to be misalinged? its "clicking" as the gear teeth fail to mesh. no amount of moving or adjusting has helped, do i have a bad regulator? any help would be great.
Mike D
Old 06-19-2003, 02:31 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Sounds like it's either the motor or the regulator..
Old 06-19-2003, 02:32 PM
Senior Advisor
Javier at Pelican Parts's Avatar
Does the motor run smoothly? are any theeth rounded out? As for the alignment, is the glass riding smoothly in the channels? perhaps the channels(seal) as slipped out. Also were the regulator connects to the glass there are two white plastic clips with metal retainers that hold it in place how's the condition of those. If none of the forementioned help in any way you might need to remove the entire assembly and inspect the regulator for any akward bends in the frame.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 06-20-2003, 10:04 AM
