adamnitti's Avatar
Send a message via AIM to adamnitti
TIP: What you DON'T want your RSM's to look like
for those of you who have heard talk of rsm's (rear shock mounts) going bad but didn't understand what was being talked about, here are pics of my pass side rsm before recently swapping out with new ground control units.
for those of you who have heard talk of rsm's going bad but didn't understand what was being talked about, here are pics of my pass side rsm before recently swapping out with new ground control units.
Bad RSM top view
Bad RSM bottom view
notice how the rubber surrounding the metal inner sleeve has cracked and is beginning to come apart. over time this would have completely separated from the rest of the mount and caused some bad clunking and eventually sm damage. you can also see that from the bottom view, the rubber surround has pretty much cracked throughout the entire circumference of the inner sleeve.
this is the kind of wear you are looking for if you want to inspect your rsm's. very necessary maintenance. let me also add that just checking one side isn't enough... if you just inspect one of them assuming that the wear will be even on both sides, you may be sorry later. my driver side rsm was completely intact.
just thought i'd share for those who were curious about what to look for...
Adam Nitti
www.adamnitti.com
...In search of the next 911...
Old 06-19-2003, 01:28 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Oh, thats nothing, on mine, the rubber center had popped completely out of the mount.
Old 06-19-2003, 01:31 PM
adamnitti's Avatar
yeah, i hear ya. i've seen that before, too. i'm trying to show folks the warning signs. these ground control units are really nice, btw.
Adam Nitti
www.adamnitti.com
Old 06-19-2003, 01:38 PM
Do they allow camber adjustment at all?
Old 06-19-2003, 03:40 PM
adamnitti's Avatar
jared, they are just shock mounts and don't provide adjustability for camber.
Adam Nitti
www.adamnitti.com
Old 06-19-2003, 04:17 PM
No i meant the ground control units. i had heard that some provide camber adjustment
Old 06-20-2003, 07:01 AM
adamnitti's Avatar
no, not the ground control units i have, anyways.
Adam Nitti
www.adamnitti.com
Old 06-20-2003, 07:02 AM
Hey, I checked out your website, You've played with Victor Wooten and Peter Erskine? WOW, color me impressed.
Old 06-20-2003, 07:17 AM
adamnitti's Avatar
thanks, man. yeah, i've been fortunate to do some really neat things. my last 2 tours were with dave weckl band and jeff coffin from the flecktones.
Adam Nitti
www.adamnitti.com
Old 06-20-2003, 07:34 AM
woah...
Old 06-20-2003, 07:35 AM
