Pelican Parts Vendor
R134a A/C Conversion Kit
Hey everyone. We shared an A/C Condenser CSF manufactures for A/C solutions a while back and wanted to share a new product they recently released for a full R134a conversion kit for the E30. It comes with everything you need for the conversion and overhaul of your system.
A/C Solutions BMW E30 Complete Conversion Kit
Current Applications:
  • E30 325e/325i (pre 10/87)
  • E30 325e/325i (10/87 – 09/89)
  • E30 325i (post 09/89)
  • E30 M3 (US & Euro Models)
Features:
  • CSF parallel flow condenser
  • Genuine SPAL 13″ straight blade pusher fan
  • Genuine Sanden SD5H14 (508) compressor
  • ACS Sanden compressor bracket
  • Interior line set (optional)
  • Low-pressure suction line (bulkhead to compressor)
  • High-pressure discharge line (compressor to drier)
  • High-pressure condenser return line (condenser to drier)
  • R134a filter drier
  • R134a expansion valve
  • Gates v-belt
  • R134a high-pressure adapter fitting
  • Compressor mounting hardware
  • Model specific R134a o-ring kit
  • Detailed installation instructions (view)
  • ACS R134a retrofit label
  • BMW to SPAL Auxiliary Fan Harness (Plug & Play) – RG-SPAL-HARNESS-BMW-PLG (optional)
  • Drop-in Fit Requires No Modifications to Install
Photos installed on an E30 M3:
Ultimate Performance Cooling
Old 07-26-2024, 10:31 AM
Administrator
Matt at Pelican Parts's Avatar
What a nifty conversion kit for an issue that can typically be such a headache! Always top notch quality products from you guys. Thanks for sharing!
Old 07-30-2024, 07:31 PM
