In Need Of A Good Tech Article
Guys, I'm lookin for a couple good tech articles on how to change/replace both headlight assemblies and corners. I'm looking to loose the stock US junk with Euro Ellipsoid/Angel Eye lamps & clear corners.
Also, does anyone know how much additional wiring is needed to incorporate the Angel Eye's? Is this a tough install without much electrical knowledge?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
check out either bav auto, hid4less or bmp...
Lots of splicing I heard is needed to install ellipsoids. You can go ahead and just buy plug and play wires from Matt (umnitza). I heard he also has the best prices for ZKWs (the best). Don't go with angel eye/inpro stuff, their quality kinda sucks. The angel eyes also dont shine that bright.
Links for ellipsoid installation: http://www.logun.org/ellipsoidinstall.htm http://www.apexcone.com/JimPowellHomepage/Lighting/EuroEllipsoids/EuroEllipsoids.html INstalling angel eyes: http://www.logun.org/AngelEyes.htm And finally, installing corners: http://www.logun.org/frclears.htm I thought you didn't like the clear corner look??? Best of luck. Make sure you get stongard or some other invisible film to put over ur new glass headlights - I've seen pitting and rock chips and they aren't pretty.
1997 M3 Sedan 5spd Artic Silver/Dove M3 Bumpers/Mirrors/Sideskirts S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes Oh wait...it's a stock M3 |
Your right Stup, I don't like the cheesie white corners, or the clear ones with the chrome housing. To me those look just too 'aftermarkety', however, I found this set that has black housing which gives it more of a 5 series 'spot' corner stock look. These are especially nice if you maintain headlights with black housing (which I plan to do), so the entire assembly seems to blend together. I'm not convinced I really need to change the side markers to clear either. If I keep my rears amber, the side will match nicely if it stays amber, thus I can keep the stock appearance I'm so fond of, yet have a cool custom look on the front of the car. Check it out.
I've seen them before in person, it looks kinda funky when the turn signal light is on. I must admit they look better in person than they do in pictures, but that is still not really my taste. I still prefer smoked or clears, but thats just my opinion. I wish there was a cheap way to get the clear/red tail lights, but there isn't. Why must we spend $200 just so that one lil strip of orange is white!?!?!
When you refer to 'clears' are you talking about the white 'chiseled' look like these.................
![]() Those seem to be the most popular choice for corner replacement, & they are the cheapest. I just don't think they add anything to the car. I mean, there is nothing subtle about them. The white lens stands out almost more than the amber, I think a clear lens allows the corner to blend in with the headlight. BTW, I hear ya on the tail light. That's one of the reasons I've held off on the corners for so long. There's no frickin way I'm gonna spend $200 a piece for one little strip of white. But by leaving the rear amber, the sides & corners look stupid in white. The way I'm doin it, I can leave the side amber to match the back, & it's irrelevant to the corners, cause they match the headlight. See, ................the boy's got skills!
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler Last edited by supertack; 08-13-2003 at 07:49 AM.. |
