BMW Roundel anyone have any info on replacing contol arms?
last post wasnt really helpful. just need some ideas to get the inner nut thast all.
thanks,
-mark
Old 11-17-2003, 03:02 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Ah yes, this one can be a pain. What I did was take an 22mm socket and about every extension piece I had, with a swivel and was able to get the driver's side off with no real problems. The passenger side is the tricky one. You cant get a socket over it, so you'll have to remove it using a large 22mm open end wrench. There is enough room to do it, but it's SLOW going getting it off. Looking back in retrospect i think I would just take the exhaust manifolds off if I had to do it again.
Old 11-17-2003, 04:09 PM
what size drive did you use? 1/2 inch drive or will 3/8 be enough? also how would you torque them ?
thanks,
-mark
Old 11-17-2003, 04:12 PM
Assuming you have new nuts to re-install, I was able to get my dremmel tool in position to slice a slot in the nut. Then a few blows with a chisel and the nut unscrewed easily.
Don Hausman
86 325e
95 325ic
Kubota B8200dt
Cessna 175a (sold)
Old 11-18-2003, 08:02 AM
of course I have new nuts, you are only supposed to use self locking nuts once.
Old 11-18-2003, 08:11 AM
Not trying to insinuate otherwise. Just pointing out that once you realize that you are going to discard the parts you are removing, other creative (destructive) means of removal come to mind. Splitting a nut is necessary sometimes. The nut splitter I have won't fit in that location so I had to find another way to split it. I labored on that nut for a long time before it came to me to just break it.
Don
Don Hausman
86 325e
95 325ic
Kubota B8200dt
Cessna 175a (sold)
Old 11-18-2003, 08:24 AM
how did you get it back on? all the rest seems simple but that inner nut looks like a total PITA
Old 11-18-2003, 08:38 AM
The nut is accessible with an combination wrench from under the car. A jack under the ball joint will keep the shaft from turning while you tighten it. I didn't try to reach a specific torque. Basically I just got it as tight as I could.
Don
Don Hausman
86 325e
95 325ic
Kubota B8200dt
Cessna 175a (sold)
Old 11-18-2003, 08:55 AM
do u tighten when the car is jacked or all the way when its in the air? or doesnt it matteR? i heard you have to tighten it when its on the suspension has a load on it.
also im replacing the bushings.
Old 11-18-2003, 09:57 AM
you'll want to tighten it with a load on the arm.
Old 11-18-2003, 09:58 AM
how do you ever do that though?
Old 11-18-2003, 09:59 AM
put the car on the ground and tighten the nut
Old 11-18-2003, 10:00 AM
ah the passenger side is easy to get to. i can actually touch it pretty easily. but how can you get to the drivers side one easier? it looks like i can reach in from under and try and get it with a wrench and remove the sway bar for enough clearance. I do have access to air tools BTW.
thanks,
-mark
Old 11-18-2003, 10:40 AM
It's my understanding that you should put the car on the ground before the lubricant you used to install the bushings dries. I haven't seen any instructions that say to tighten the ball joint with the car on the ground.
Don Hausman
86 325e
95 325ic
Kubota B8200dt
Cessna 175a (sold)
Old 11-18-2003, 12:02 PM
I found the pass. side easier by removing the engine mount
Old 12-05-2003, 05:58 PM
jase007's Avatar
I have replaced control arms 2X on my '90 iX and I have tightened the inner ball joint when car was in the air. I too have not found instructions saying otherwise. Perhaps one solution could be to drive it up on ramps to give some clearance (mine is lowered).
Jason
Jason
'58 -'76 P-cars
SSPI ~ JScott Racing
Old 12-10-2003, 07:21 AM
randini74's Avatar
I did it while on jacks as well. I'm too fat to get that far under the old grey ghost when she's not on jacks.
One solution for those who prefer to load their suspensions before tightening the nut is too take yet another jack and lift the wheel on the side being tightened.
Old 01-03-2004, 09:56 PM
