Unhappy Brake Problem Too
i just recently change my pads and after changing it when i press on the brake it goes smoothly until it reach to a stop it sound likes there's a dragging noise to it before the car completely stops. please help.. is this a safety hazard?
Old 03-31-2004, 07:38 PM
carolinus's Avatar
Yes. This is a hazard, depending on the sound. Go and find out wth is wrong asap. One of your caliper bolts could be loose...or a pad installed backwards, or the spring clips might have fallen off/broken/been installed wrong. Your pad sensor could be loose and being crushed when you hit the brakes. Really, the list goes on.
What type of dragging noise is it?
Are your rotors old/rusty? If so, that can do it too. If is about the only thing that wouldn't warrant freaking out. Sometimes they take a while to wear similar grooves in the brake pads as the rotors, and will make noise. Or you could be scaling rust off.
I am blessed/cursed with these cars:
BMW 318iS 1991
BMW 325iS 1988
Volvo 740 Turbo Wagon 1992
Quote of the week:
"This chemical is known to cause Birth Defects in California."
Poor Californians, they are always getting the short end of it, and now this?
Old 03-31-2004, 07:45 PM
all the bolts are tight as far as placing it backwards i doubt it because i double check everything before i install the wheels back. this thing only happen before going to a stop but as far as breaking from about 20 or 15 mph it's really smooth except when before stoping then it make this weird sound. my dad told me that this is normal since i replaced a new pads on my brakes but i just want to get a second opinion about it. and the car stops right away when i press on the brake it just have this weird sound.
Old 03-31-2004, 09:35 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
check EVERYTHING! It could be a loose caliper mounting bolt.
Did you re-surface the brake rotors or use new rotors when you put in new pads?
Old 04-01-2004, 08:12 AM
did nothing with the rotors just paited the caliper and change the pads
Old 04-01-2004, 09:07 AM
Well, thats probably the source of the noiser then. The pads trying to seat into the old rotors..
Old 04-01-2004, 09:09 AM
Red face
i'll try to drive the car this weekend to see if it will be quieter... thanks for all the help. draging and clunking are two different thing right?
Old 04-01-2004, 09:29 AM
