MAXI's Avatar
air intake & air sensor
I wana install a peformance air filter but there is no place for ire sensor, where must I put that sesonr?igonr??. all peformance air filter approxmetaly like this.
is there good air come special for bmw E 36.
BMW DRIVER
Old 04-04-2004, 03:46 AM
Ad Hoc's Avatar
Are you asking about installing a cold air intake (CAI) system and where to relocate the temperature sensor that is currently bolted to the stock air box (for E36s through '95)?
If that is your question, it depends whose CAI system you have. Some systems have you mount it to the heat shield itself while others have a mounting location on the intake tube. In any event (presuming we are talking about a '95 or older E36) as long as the sensor is reading the temperature anywhere INSIDE the shielded compartment (i.e., the cold air), you should be fine.
If the above is NOT what you were asking, you may want to elaborate - or translate.
Old 04-04-2004, 02:45 PM
MAXI's Avatar
Thanks Frind , Yes that's what I'm wonderign about. my Car is 92 Model 320i.Could U put picture explain mounting CIA to the heat shield.
Do you know some suitable CIA for my car come with box or something protect CIA from hot engine air & give good Power(What's better ).
BMW DRIVER
Old 04-04-2004, 09:39 PM
Ad Hoc's Avatar
First, there will always be differing opinions as to which CAI system is better based on many variables (e.g., appearance, ease of installation, dino results). Performance-wise, from the dino results I have seen, most CAI systems are equal. If others reply to this post, you will most likely get many different suggestions.
Personally, I use the CAI from East Coast Induction Systems (ECIS). I liked their setup and am friendly with the owner, Kenny (my office is 20 minutes from his). If you check their site below, take a look at the installation instruction for photos and descriptions for the E36 setup:
http://www.ecisbmw.com/product_files/intakes/intakes.htm
Note, however, that you will need to inquire from anyone you choose for your CAI system as to your specific model (the 320i). Nevertheless, in the ECIS system fro my '93 325i, the temperature sensor bolts onto a pre-cut hole in the heat shield, allowing the sensor to read the temperature inside the shielded area.
My only advice as to any CAI is make sure you use a heat shield. Some suppliers sell (and some E36 owners install) just the intake tube and cone filter. If you don't shield the intake from engine heat, you sort of defeat the benefit of using cooler air.
Good luck.
Old 04-05-2004, 07:36 AM
stupenal's Avatar
you dont really need that unless you live in a cold climate. i currently have mine just lying in the engine bay doing nothing.
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 04-05-2004, 11:43 PM
