The rubber piping around the exterior of my convertible window popped off. THis is on a '98 BMW 328i. I need suggestions (other than super glue) for the correct adhesive to use to fix. Here is a pic:
what is that tar like stuff that they put new windows in with???
Goop automotive, maybe?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
butyl tape is what it is. Napa sells it around 10 dollars its rolled up in a i think 20 foot role comes in different size diameters. This stuff is also used for the door vaper barriers to keep them sealed
In the shop at Pelican
butyl tape does work, just be sure to clean the area well
door vaper?
What is the door vaper? I have an issure where when I put my window up, it lifts the rubber seal away from where it was attached. This allows air to get in. Is this what you are talking about?
use some clear silicone adhesive
1993 325IS Turbo T3/T04e M3 Cams Last edited by Geno325is; 05-24-2004 at 08:12 AM.. |
Administrator
Re: door vaper?
I think most carmakers use a thin but tough clear vinyl film stuff, kinda like really beefy plastic wrap. I've seen everything up to and including sliced-open Hefty kitchen garbage bags used, though... --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
butyl tape
"butyl tape does work, just be sure to clean the area well"
What is the best thing to use for cleaning? Can this tape also be used for rubber stripping around the windows? Thanks! Mike |
Don't go with the butyl tape... take Geno's input and use the silicone adhesive. The reason? This is a piece that is exposed to the environment all the time... heat, UV, cold, wet, dirt, etc. The butyl tape has adhesive that will turn soft and let go with heat, plus it will collect dirt... many other things. The silicone or RTV (room temperature vulcanization) polymer will cure to a solid that will never let go, no matter what the environment (well, to a point ya know). Silicone is resilient as hell, which is why it is used for so many seal and adhesive purposes. Just got to the Depot or Lowe's... they'll have a selection and you can choose the one that is the best fit.
Oh, and yes Mike, this stuff can be used for the rubber stripping around the windows too. I would go with the clear sealant just so clean up isn't as critical and you can be a little more generous with the amount you use. |
Have you done this?
Blkongray,
Have you made this repair? I tried Marine Goop which is essentially clear silicone. It did not hold and now the trim is coming off even more. Have you had to repair yours or have you done this? Did it work?
I've repaired the straight portions of the rear lip, but not where it flexes. Once it breaks away at the flex area, it's pretty hard to get it to stay. I used a flexible silicone adhesive (can't remember what brand), but if I were to do it again, I'd probably use contact cement for vinyl and vinyl coated fabrics... since it seems directly suited to the purpose. I don't know where you can get it other than through McMaster-Carr www.mcmaster.com Item#7507A2. The silicone is good for a durable weather-resistant repair, but if the repair is pulled taught (like yours is since it is around the rear corner), the contact cement will probably have greater holding power.
Author of "101 Projects"
I like 3M Super WeatherStrip. Very strong stuff...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
