Timing plug removed by error, Question
93 325i with 100,000 miles
The water pump went (old plastic impeller type) so I replaced it. When draining the antifreeze I mistakenly remove the primary timing chain tension cover plug. I thought it was the antifreeze engine block drain.
I put the plug and spring right back when I realized it was not for the coolant. Nothing was moved on the engine.
Do I have anything to be worried about??????
Thanks for any advise.
Old 07-16-2004, 10:53 AM
As long as you got the tensioner back in correctly >>slot going sideways>>then everythings good~
Old 07-17-2004, 05:55 PM
