Unhappy E30 Evo II wont Start!!
HELP!!
Long story short...
Battery went flat due to lights left on, Went to jump start the car and it kept turning but would not fire. Removed the plugs and they were not wet. Checked for spark and it is there for all plugs. There is some fuel rail pressure but it is low, def. not 4bar! There is no whine from the fuel pump (external fuel pump), checked relays and fuses and all appear to be ok. It is not the immobiliser either. Can anyone help? It used to start with no problems.... has the battery going dead affected something? Turning on the key only showed a voltage of about 0.2V accross the terminals of the fuel pump........ I have no owners manual for the car and as it is an Italian import, everything is in Italian! Is it my pump, DME, wiring? fuses or relays somewhere.... the only ones I can find are those in the fuse/relay box under the hood.
Please help!
Thanks in advance,
Aidan
Old 08-14-2004, 02:01 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
How did you try to jump start it? Sometimes, that can fry the DME...
Old 08-30-2004, 02:29 PM
