Question Bmw E36 1996 Fails At Start
I have a 96´ 328iA BMW auto...
The first time I start the engine in the morning the engine the engine keeps failing until I press generously the throtlle...
I´ve already cleaned the injection and changed the fuel filter but the trouble still remains...
anyone can help me?
Old 01-03-2005, 02:55 PM
If I remember right there is an "idle stabilizing solenoid" that can cause this problem when it fails.
Old 01-03-2005, 04:11 PM
solution
how can I solve this???
Old 01-03-2005, 04:21 PM
LeRoux Strydom's Avatar
Yup, it sounds like the idle control valve (ICV). It may just be dirty and can be cleaned out with carb cleaner. Look for the solenoid-type device sitting in the rubber boot between the air flow meter and the intake manifold. Easy to replace if cleaning it does not help.
Does the car run fine once warmed up? Difficult idling/starting when hot/cold may also point to a bad DME. Search for "wet DME", there are plenty of previous threads on the topic.
LeRoux
'90 964 C2 coupe (sold )
There are no old Porsches, only new owners.
Old 01-10-2005, 06:05 AM
Jeron's Avatar
In this thread, I give a detailed description of changing the ICV on an E36 M3. Hope it helps. My symptom sounds similar to yours but cleaning didn't fix it, I replaced it.
Rough idle at startup
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-10-2005, 09:33 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
9 times out of 10, cleaning the ICV does the trick, you need to remove it, spray some carb cleaner in there and free up the little slide inside... It's ok to use a small screwdriver to carefully work the slide back and forth while spraying to free it up...
Old 01-10-2005, 10:23 PM
do anyone have some pics on how to remove and clean it???
regards...
Old 01-11-2005, 06:07 AM
Jeron's Avatar
Did you read the thread I linked in my first post? It doesn't have pics but it is very detailed. I'm just not sure if the 328 ICV location is the same as the M3.
Old 01-11-2005, 08:05 AM
