jetmax's Avatar
Send a message via AIM to jetmax Send a message via Yahoo to jetmax
FIXED** Directional buttons on climate not working.
The directional buttons on my heater controle don't work. They light up, but air does not change vents. It always comes out the front vents. I really need to get this fixed so I can defrost the front winshield and warm my toes from time to time.
I have just replaced the heater controle unit in hopes of fixing the problem, but that only fixed the turning off and on gremlin problem.
Is there another controle module, or linkage that I need to check, replace, or fix that you know of?
John
jmaxvill@hotmaill.com
1996 318i 4dr
1990 944S2 Cab - over 215k miles
jmaxvill@hotmail.com
Old 02-28-2005, 09:50 AM
jetmax's Avatar
Spoke with dealer and he said the climate control needs to be programmed.
Does this sound familiar to anyone?
Old 03-08-2005, 05:29 AM
No. it sounds like the ihka unit is bad. the control unit. or a stepper motor, but the control unit is a common problem.
1991 nissan 240sx
sr20det cp pistons, eagle rods, 740cc inj, k3t turbo, jwt s4 cams, lots of duct tape, GReddy headgasket
Old 03-11-2005, 09:24 AM
jetmax's Avatar
Thumbs up FIXED
Took it to the dealer and the climate unit is working fine. It turned out to be two vacuum hoses that became disconnected. It seems that the vent direction is powered by a vacuum motor. I'm not sure where the two vacuum lines were (under dash, under car, in engine bay), but it's fixed now. Only cost me $230 grrrr, damn dealers!
He did say that my blower motor is cutting off intermittently. Said I needed a new blower motor at $500 installed. I'll just wait till it completely gives out before I even consider this job.
Old 11-23-2005, 07:27 AM
Jeron's Avatar
$230 ouch.
The blower is acomon problem and it is usually the resistor pack or coil pack. Do a few searches and you will find several threads. One as recently as this week.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 11-23-2005, 04:20 PM
crashthecar's Avatar
Send a message via Yahoo to crashthecar
The motors also cut out intermittantly when the brushes are worn and not making good connection with the commutator.
I pulled my fan out and and soldered in a new set of brushes. Just took them down to the local Jcar (radio shack) and got them to match up a set.
The fan is relitivly easy to remove on an E36 the Bentley shows the jpb step by step. This saves replacing an otherwise good fan and saves $$$!
Bugger this for a joke...
Old 12-05-2005, 01:46 PM
