325 valve cover gasket replacement
hey guys,
Trying to replace my valve cover gasket this weekend. I've been leaking oil into the spark plug wells for about 5-10K miles now. Noticed the problem at the last spark plug change (5K miles ago) I want to change it before it starts causing any bigger problems.
I ordered the valve cover gasket from pelican, and after i recieved it, it only includes the 2 outer gasket pieces, and does not include the "donuts" that seal the spark plug wells, which are the pieces i need! I have not disassembled anything yet, and want to make sure i have all the parts before i start taking anything apart. What else do i need? anyone have a blowup parts diagram of the valve cover gaskets?
Thanks.
Mike
Old 01-16-2004, 08:02 AM
Step On It!'s Avatar
call and ask.
Old 01-19-2004, 08:44 AM
Pink Floyd's Avatar
Send a message via AIM to Pink Floyd
Same thing happened to me. I don't see the spart plug gaskets for my car on this site. You can go to them. They sell a valve cover set that comes with all the gaskets and even all new bolts and bolt seals.
Old 10-03-2004, 03:44 PM
Cool
I found this link very helpful:
http://home.earthlink.net/~frankie66/cars-bmw_diy_valvecover.html
I just did this very job myself. I repainted my valve cover since it was a lot cheaper than getting a new one.
Good luck.......easy job, but takes a while.
1995 325i
Old 10-06-2004, 08:26 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
FYI, I have added these seals to the site... Sorry about the confusion before.
Old 10-06-2004, 01:27 PM
Hi All
I have a 97 528i, and am starting to see some seepage around the gasket. How bad should I let it get before replacement? Thanks!
Thanks for posting the tutoria...very helpful.
Beerguy
Old 08-04-2005, 05:26 PM
Jeron's Avatar
Is the seepage on the perimeter or in the spark plug wells? Significant seepage into the spark plug wells will become a problem. The perimeter is a nuisance but I wouldn't let it get too bad. If you want to postpone it you can might try putting just a tiny bit of torque on the cover bolts.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-04-2005, 08:35 PM
