odometer coding plug
I have to replace my instrument pod in a 318 tourer 1996. That bit I can do, however the BMW main dealer tells me that I have to have the unit coded otherwise it will not work. Can I do this myself as the main dealer rates in the UK are bordering on the criminal!!!
Old 04-02-2006, 11:55 PM
BMW Roundel
No, you cant code it urself
Old 04-10-2006, 05:14 PM
supertack's Avatar
You can do an instrument cluster swap, & the new one WILL work. What happens is the new cluster will illuminate a light (on speedo below the highest mph marking) that indicates the cluster is new, & thus the odometer mileage is not accurate. This is why you need a BMW tech to code your new cluster, so that light goes away.
I wouldn't feel obligated to take it to the stealership though, just find a local shop, & see if they can do it. Any place that does work on Bimmers should have the equipment to do that.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 04-11-2006, 09:16 AM
Thanks for the reply. I have found a local BMW specialist (not main dealer) who can do this for me. The main dealers over here will not give me an accurate time or price for this job, so you never know what the bill is going to until you go to collect the car. I wish i could have a licence to print money like that!!
Old 04-12-2006, 08:48 AM
supertack's Avatar
Originally posted by ianben
I wish i could have a license to print money like that!!
I know, pretty amazing that most folks just let 'em get away with that. I've used the same guy from a local shop for years. Never screwed me, & now I'm at a point where if I need a simple suggestion or his thoughts, I can call & get it. It's almost like having a good doctor your comfortable with.
97 328is
Old 04-12-2006, 09:51 AM
