e36 Business CD: Security Code Input help?
This may seem like an idiotic question, but I recently received a used OEM Business CD RDS (CD23; Blaupunkt Model BP3850) from a 1994 e36. It's replacing an older unit which does not use the same type of security, and I DO NOT have a manual. The unit came with a 4-digit security code, but some of the numbers are higher (let's say "9999" for argument's sake) than the face numbers on the preset buttons ("1"-"6"), which leads me to believe that the input method for the code is NOT just pressing the preset buttons, as it is for older units. Or, it's a bogus code (which I tend to doubt since I have the actual Radiopass card).
Can anyone with this unit (or this type of unit) let me know the code input process? I'd really appreciate the help.
Thud
Old 04-13-2006, 11:21 PM
supertack's Avatar
Funny! When I bought my '97 328is, the radio pass card also had code numbers higher than 6, & as you well know, six is the highest digit on the number buttons.
I pulled the radio, noted the serial number, & called a local shop with that number & my vin number. They were able to give me the CORRECT code, because obviously the one on the card was bunk.
You can probably do the same with a local BMW dealership as well. Just explain your situation, & I'm sure they can hook you up.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 04-14-2006, 08:19 AM
Good to know it's not just me. I'll bring it by my dealership tomorrow. Thanks a lot for the tip supertack; much appreciated.
Thud
Old 04-15-2006, 12:21 AM
