supertack's Avatar
'Check Coolant Level' OBC message
I keep getting this intermittent 'check coolant level' message, but every time I check the tank, it's already full. My first guess was the sensor, but I had the radiator & thermostat replaced last year, & I would assume the sensor woulda been replaced with the radiator.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 08-10-2006, 07:04 AM
Jeron's Avatar
I replaced my float sensor years ago and it didn't fix the problem.
Others have identified the problem as a crack/break inside the expansion tank. I noticed a piece of loose plastic inside my tank last time I flushed it so I suspect that the broken expansion tank is the problem.
I think it was discussed here a few weeks ago. I also think I've heard of one person that has fixed the problem by replacing the tank but I cant be sure.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-10-2006, 07:49 AM
Author of "101 Projects"
Wayne 962's Avatar
Re: 'Check Coolant Level' OBC message
Nope, the sensor is not typically replaced with the radiator - it's in a separate area. Also, this may be a sign of bubbles or air pockets in your system, as the coolant level may be low while you're driving and then pop back up again when at idle.
I would replace the sensor, and then rebleed the entire system, and that should solve the problem. If not, then you'll have to investigate further...
-Wayne
Old 08-10-2006, 01:19 PM
supertack's Avatar
Where is the sensor located, & how accessible is it? Any tech article on the job, or is this gonna be another plug to buy your book?
97 328is
Old 08-16-2006, 04:20 AM
Jeron's Avatar
The sensor is at the bottom of the reservoir. It has a big plastic nut holding it in that simply screws off. It wont hurt to replace it but I don't know of anyone that has solved their problem this way. The new reservoir comes with the sensor, IIRC.
You may need to remove the lower rad hose because it interferes with removing the sensor so be prepared to top off with a 50/50 coolant mixture. And make sure you use the same coolant otherwise flush the whole thing.
Old 08-16-2006, 06:17 AM
