Wayne -
What size of flare wrench do I need for this project on my 1998 328is? I am planning on replacing the clutch line too, any extra thoughts on that?
Old 10-19-2006, 08:46 AM
Jeron's Avatar
I used an 11, 14 and 17mm when I did my CDV delete.
I would bleed the clutch slave before reinstalling it by turning the bleed nipple up and compressing the piston with one hand while cracking open the nipple with the other. The reason for this is when installed the nipple points down allowing air to remain trapped.
Make sure when you stab the slave into the tranny that the piston rod hits the fork. Its a big target but if you put the piston rod in a a severe angle you can miss the fork and you will destroy your slave when you try to use the clutch. When you install the slave you will know if you hit the fork because you will have to press and hold the slave body onto the tranny with one hand while threading the nuts with the other.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 10-19-2006, 12:03 PM
Author of "101 Projects"
Wayne 962's Avatar
Hmm, good question on the sizing, I'm not sure - I have a few sizes, I just pulled out of my toolbox. Off the top of my head, I think it's 11mm - I know it's that size on the Porsches...
-Wayne
Old 10-26-2006, 12:07 AM
OK -
I should be able to make it work. I just don't have "flare" wrenches so I was going to go get a couple so I don't strip the connections.
Thanks!
Old 10-26-2006, 07:29 AM
Wayne 962's Avatar
That's smart - please don't try to do it without using the wrench (I have tried in the past). It's not worth it, as it's much more difficult to replace the line (well, actually this line is pretty easy, but the hard brake lines on a Porsche 356 are *not*).
-Wayne
Old 10-27-2006, 05:22 AM
