| Registered Join Date: Jan 2007
				Oxygen sensor locations
			I have a 97 328i sedan m52 block,,,I keep getting a ... check engine light code 'oxygen sensor slow response' ,,,,,,,Bank1,Sensor1.. on my OBD2 reader,,where is this sensor located on the engine?...and does anyone know what the BMW part # is..Thanks John | ||
|  01-13-2007, 08:39 AM |
| Moderator |
			Your four O2 sensors are on the exhaust. Sensor 1 means pre-cat which is on the manifold and Bank 1 means the front most manifold. Clear the code and see if it returns. You "can" swap sensors to make sure it is the sensor if the symptom follows but they can be hard to remove so replacement might be a better option.
				__________________ HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 | ||
|  01-17-2007, 09:17 AM |
