R_F_L's Avatar
ABS Light on But no Fault Codes (92 325is)
My ABS light is starting to pop up after driving for a couple of minutes. The last time it did this was over a month ago just once, but now it's doing it a couple of minutes after every time I drive.
I read a couple of posts about the problem but most were odd problems. I thought it might be worn out brakes or sensors but the pro's say otherwise. Though there is a rattling-metal noise coming from the back that I'm starting hear often, could it have anything to do with it? Any help is much appreciated.
95 Silver/Dove Gray M3 - Dinan Chipped - Cold air Intake - SSR GT3 18X8.5 - Bilistein
In the works: '91 325ic 2.7l stroker pending turbo install
Old 05-28-2007, 11:45 AM
Jeron's Avatar
Probably pedal pressure sensor or a wheel speed sensor.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-29-2007, 07:21 AM
R_F_L's Avatar
Ok, how do I troubleshoot that? I didn't see any article on this issue on the site.
Old 05-30-2007, 12:33 PM
Jeron's Avatar
Thats the hard question and its even harder because yours is OBD-I. I dont know if OBD-I stores the ABS errors, so you might have to take it to the dealer or a BMW mechanic.
There might be a Peake reader that can pull it, check them out.
Old 05-30-2007, 12:35 PM
