Reverse Light issues
Hey guys -- have an issue with the reverse light on my M3 not working at all
the car just past NY state inspection not more the a month ago so they were working then. The bulbs are fine and theres little chance of them both blowing at the same time
Is there a switch in the transmission that may be out of place or is there simply a fuse that could be making this a problem
The comp is stating tail light failure every time the lights come on but yet everything is working except for my reverse light
Some ideas would be great
thanks
Old 08-07-2007, 09:37 PM
Jeron's Avatar
I assume its a manual tranny. What year?
There is a switch on the tranny it can go bad and the wires can be damaged. I would either start there or in the trunk wiring.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-08-2007, 07:42 AM
yes its a manual tranny year 96
thanks for the tip ill go after the tranny switch first -- I'm pretty sure the wiring is ok back there but ill see what i can find
Old 08-08-2007, 09:05 AM
Jeron's Avatar
After early 96 BMW fixed a wire problem by putting a shield around the wires where they enter the trunk. So check the wires where they enter the deck lid.
Old 08-08-2007, 11:48 AM
