Send a message via AIM to thedude60526
Power steering problems
I just replaced my power steering pump and when I tried the bleed it bubbles just keep coming up. I must have turned the steering wheel for 6 or 7 minutes strait and it didn't finish it. Any ideas?
Old 08-23-2007, 08:19 AM
Jeron's Avatar
You shouldnt need to bleed it. Just fill it, run it and turn the wheel lock to lock a few times and top it off. Check it again in a few days just to be certain.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-23-2007, 08:22 AM
ok so if that is not working what should I check?
Old 08-23-2007, 08:25 AM
Could I have hooked one of my lines up wrong?
Old 08-23-2007, 08:26 AM
Jeron's Avatar
What isn't working? No power assist?
If the pump is new and the belt is tight and spinning the pump then it must be the rack.
Any leaks?
Old 08-23-2007, 08:27 AM
Jeron's Avatar
I don't think you can hook up the lines wrong because the reservoir nibs are different sizes and the hoses are different too.
Old 08-23-2007, 08:28 AM
ok no it was a used pump This is very annoying
Old 08-23-2007, 08:29 AM
nott you just been trying to get this to work for days thanks
Old 08-23-2007, 08:30 AM
it is just making the whinning noise and is constantly shooting up some pretty big bubbles
Old 08-23-2007, 08:33 AM
if the lines to or from the pump were twisted it can restrict the flow and cause this condition. you can loosen the hose clamps and see if the want to twist to a straighter position.
gONe
Old 08-23-2007, 02:24 PM
