Removing starter
Is it true that to remove the starter on an m42 it is necessary to remove the intake manifold, or the transmission to gain access, I read this in a manual?
95 318is, stock, burgundy exterior, 2 one baige interior, automatic, 180kmiles |
No. You may have to remove the dipstick tube to get at the upper starter motor bolt, but it will come out with everything else in place. It's TIGHT, and a puzzle to get it rotated around to drop down through the engine bay, but it will come out. Getting the bolts out (and back in) is the "fun" part.
--------------------------------------- '95 318is, Boston Green, beige leather, auto, 191K miles Last edited by hornhospital; 01-22-2008 at 04:51 PM.. |
You dont have to remove the intake manifold or the tranny.
You should remove the intake tubing to the manifold. If the bolts don't thread into the starter itself (the starter housing isn't threaded) then you will have to hold the nuts while turning the bolts. This is not an easy job and may require several socket extensions.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
