Mercedes are ugly
BMW Roundel front end vibration
Iīm having a serious vibration coming from the driverīs side front wheel area, but it only occurs at somewhat high speeds (70 mph+). Most of the time I drive at much lower speeds, so it rarely bothers me. But sometimes on the highway my engine keeps asking for more when soccer moms change lanes to pass me by in their minivans like "you're driving a bmw...why are you slowing everybody down?".
I drove 4 hours (each way) to Washington DC some time ago, at higher speeds, (don't make me say how high, never know who's looking) and everything was fine other than a flat tire. One day after coming back I noticed the mentioned vibration, so I slowed down and it stopped, so I kept going. Should I suspect something tire/wheel related, since the vibration comes from where I had the flat? I had to replace that tire, not just repair it. Or could it be ball-bearing or suspension related? I just don't know what to look for.
Old 02-17-2008, 09:56 PM
Make sure that the suspected wheel is properly balanced.
Old 02-18-2008, 05:37 AM
Jeron's Avatar
check balance
lugs tightened properly and in sequence
hub mating surface and wheel mating surface clear of debris
The flat tire was replaced with a new tire, correct?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 02-18-2008, 06:47 PM
Mercedes are ugly
well, technically, no, because I mounted a slightly used tire on that wheel, but I had it balanced though....can the fact that the tire is used be the cause?
Old 02-21-2008, 08:33 PM
Yes it could, especially if this tire was used on a different car before.
Old 02-22-2008, 06:03 AM
Mercedes are ugly
ok, thank you very much Yurick and Jeron. I'll see what I can do.
Old 02-22-2008, 08:37 PM
